I really like this case but the issue is their stock fans are crap. When I first got the case the top fan made lots of noise most likely due to bad bearings. Amazon sent me a replacement and now this one has the same issue. I am sure it is a design flaw as it only has an issue in a horizontal position. Literally if I dismount it and put it vertical then turn on the PC it will be quiet then I can remount it, however it will just make noise again on next start up. I think the bearing ends up shifting. There really isn't a lot of choice when it comes to 200m fans so I was wondering what you guys would suggest I replace it with and I don't want a third crappy stock fan.
I am currently leaning towards the following
https://www.amazon.com/gp/product/B008G3OLRQ/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
