I bought a GPlay Samurai PC recently and several things caught my eye.
1. Since I was dumb enough to enable the "Chassis Intrude" protection it kept giving me that error and locking me out of BIOS. I had to open the case and remove the CMOS battery.
2. When I first started the computer the Chassis fan on the rear panel wasn't working, but still lit by the bright blue LEDs.
3. When I opened the case my front panel USBs weren't connected to the motherboard, so I connected them. However, their cable was stuck in the aforementioned fan's blades, possibly blocking its spinning.
4. The fan is connected via a small cable to a 4-pin cable coming from my SSD, and I can't find a free spot to connect it to the motherboard (the fan still works, mind you).
Now, to the real question.
On my older system my CPU fan worked at 950-1000 RPM regardless of temperatures. I didn't know that until recently, because it used to be controlled by the BIOS and wouldn't respond to SpeedFan's manual control. Then I installed Speccy and it showed the same 950ish RPM at SEVENTY DEGREES CELSIUS! I went into the BIOS, disabled "Smart Fan" and the CPU began spinning at 4500 RPM immediately. Now SpeedFan controls it.
(Ignore the clock generator by the way. I never intended to overclock my CPU; set it out of curiosity but it isn't active [no ACER motherboards are in the list anyway])
How does that tie to my new system?
SpeedFan shows a bunch of Aux/GPU fans with 0 RPM, which don't exist. I was like "Sure, it's a 6-year-old PC, the motherboard must be pretty outdated". But when I installed Speccy and SpeedFan on my new PC they also show non-existent Aux Fans at 0 RPM, don't detect my GPU Fan (as if I don't have one) or the Chassis Fan.
My CPU Fan is being controlled by the BIOS, the GPU Fan - by GPU TweakII (came with the drivers), but my Chassis Fan is not being controlled by anything and I'm missing on at least 33% extra cooling if ever needed, right? So, how can I make my motherboard (BIOS) or any software detect and control that fan, if possible?
