[SOLVED] Chassis fan RPM info not showing
bumblebee953
132
Hi all, I recently finished bulding my new system, and one thing is bugging me a little...
I have an AIO hooked up to the CPU_FAN header, and 1 exhaust fan hooked up to the CHA_FAN_3 header, and 3 intake fans all plugged into my case's fan hub which then is hooked up to the CHA_FAN_2 header. CHA_FAN_1 is not used.
Looking in both ASUS UEFI EZ Mode, and HWInfo, there are no RPM info showing for the CHA_FAN_2. In UEFI EzMode it shows CPU_FAN and CHA_FAN_3 rpm infos, but CHA_FAN_2 just says "N/A". In HWInfo, it shows CPU, Chassis 3 rpms but no Chassis 2.
Interesting thing is, in the BIOS Q-Fan Control I can still set the fan curve for CHA_2 (I like intakes at 100%, which is what I set them at), and I can audibly notice the fans respond to that setting, but it's just no RPM info is actually shown. As long as it is indeed running at max RPM, I'm ok but it'd still be nice just to be able to check sometimes.
Here are my specs:
Phanteks Evolv X
ASUS X570 ROG Crosshair Dark Hero (running latest BIOS ver 3003)
AMD Ryzen 7 5800X
Deepcool Castle 360EX AIO
3x 140mm Phanteks F140MP intake fans on front (CHA_2 via case fan hub)
1x 140mm Phanteks F140MP exhaust fan in rear (CHA_3)
3x120MM Phanteks F120MP rad fans for AIO (CPU_FAN)
Gigabyte RTX 3070 Vision OC
Thanks for any help!
