G Gze Reputable Jan 11, 2015 121 0 4,710 May 9, 2015 #1 I have just bought a new fan for my pc, however when I plug it into a 3 pin on the motherboard my pc cannot boot, pressing the power button does nothing. However, when I take the fan out the pc automatically boots. Is this a faulty fan?
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 May 9, 2015 Solution #2 have you tried it on a different fan header? Upvote 0 Downvote Solution
G Gze Reputable Jan 11, 2015 121 0 4,710 May 9, 2015 #3 mcnumpty23 : have you tried it on a different fan header? Only got 1 fan header Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 May 9, 2015 #4 Gze : mcnumpty23 : have you tried it on a different fan header? Only got 1 fan header could be the fan thats faulty or could be the fan header without a spare header to double check its hard to tell Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 May 9, 2015 #5 might be a silly question--but the new fan is 3 pin not 4? Upvote 0 Downvote
G Gze Reputable Jan 11, 2015 121 0 4,710 May 9, 2015 #6 mcnumpty23 : might be a silly question--but the new fan is 3 pin not 4? Yes it's 3 pin Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 May 9, 2015 #8 got a friend with a pc you could test it in? or if you got the fan from a shop not off the internet take it back if you got it off the net you got return postage and waiting time etc if you rma it Upvote 0 Downvote
G Gze Reputable Jan 11, 2015 121 0 4,710 May 10, 2015 #9 Just put it in the cpu header, works fine Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 May 10, 2015 #10 guess you have a faulty fan header then Upvote 0 Downvote
