I have a question for anyone who can tell me if I can make this work. So I have 3 chassis fans with 3 pin connectors on them, I think what I did with my last mobo is plug them into the 4 pin system fan connections on the board and it would work.
This mobo here that I'm likely going to buy says it has "2 x Chassis Fan connector(s) (2 x 4 -pin)" for my third chassis fan I'm assuming I'll need an adaptor to get it working? Or is there somewhere else I can plug that in too?
https://www.asus.com/us/Motherboards/PRIME-Z270-A/specifications/
1 x Aura RGB Strip Header 1 x USB 3.1 Gen 1 connector(s) support(s) additional 2 USB 3.1 Gen 1 port(s) (19-pin) 3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s) 1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110 storage devices support (SATA mode & X4 PCIE mode) 1 x M.2 Socket 3 with M Key, type 2242/2260/2280 storage devices support (PCIE mode only) 6 x SATA 6Gb/s connector(s) 1 x CPU Fan connector(s) (1 x 4 -pin) 1 x CPU OPT Fan connector(s) (1 x 4 -pin) 2 x Chassis Fan connector(s) (2 x 4 -pin) 1 x Thunderbolt header(s) 1 x 24-pin EATX Power connector(s) 1 x 8-pin ATX 12V Power connector(s) 1 x EZ XMP switch 1 x Front panel audio connector(s) (AAFP) 1 x System panel(s) (Q-Connector) (Chassis intrusion header is inbuilt) 1 x 5-pin EXT_FAN(Extension Fan) connector 1 x MemOK! button(s) 1 x CPU OV 1 x Power-on button(s) 1 x Clear CMOS jumper(s) 1 x 14-1 pin TPM connector 1 x COM port header 1 x High AMP Fan header (4-pin) 1 x T_Sensor Connector 1 x AIO PUMP Header 2 x 3D Mount screw port(s)
