Ej-_- :
Tolis_GR :
It's use is for installing a "beep" speaker in your case, when your motherboard does not have one integrated. If your mobo has speaker, you can simply ignore it
Thanks for replying, what do you mean by Installing a "beep"? Is th
is the one that beeps when your turn on your desktop and hear a beep sound ?
Yes that's it. Not only this, but whenever there is a problem, usually there are different combinations of "beeps" that indicate where the problem is located ie 3 beeps=ram, 2+1 beeps=gpu etc
