TP-Link unveils a family of new 2.5GbE & 10GbE switches for homes and offices.
Cheap 2.5GbE & 10GbE Switches Come to the U.S., Starting at $130 : Read more
Slightly more affordable, sure. Cheap? $100+ is still way too expensive for that. The price needs to be at least proportional with performance before I'd be willing to call them that, so they need to come down another ~50% before I get remotely interested. I doubt I'll have 2.5GbE in more than my next PC for another 5-10 years, plenty of time for prices to trickle down.
My sister has 1Gbps FTTH and her home is all-WiFi, nothing plugged into her ONT, not even the STB for her living room TV which is 6" from the ONT. I suspect this is the prevalent setup for non-enthusiasts at least as long as everything is within the modem-router's range. I might be doing wireless myself if my main PC wasn't 3' from the modem and router and I already had plenty of cables.I have 2 desktops, 2 work laptops, 2 tablets, 2 phones, and 2 UHD TV's I stream movies and shows on but I still do not think I have a use case for this. Even if I got gigabyte internet I bet I could do without this.
1GbE didn't become mainstream until it became baseline - you literally couldn't buy a new PC without 1GbE by the time 1GbE routers became prevalent.I can't see how anyone is wasting time and money on 2.5 and 5GbE technologies when the world is obviously heading straight to 10.
Can be more specific what you mean with "the world"? What part of the world (country) is that?I can't see how anyone is wasting time and money on 2.5 and 5GbE technologies when the world is obviously heading straight to 10.
2.5GbE and 5GbE were created because most people and companies with in-wall/ceiling wiring don't want to replace wiring for 10GBase-T.
Yes, 10G exists quite a while, but is mainly used for serious stuff and is still way too expensive for home use.
The difference may be small now but that is only because 2.5GBase-T is only slightly less of a niche market than 10GBase-T currently is. Mass market will drive the price down to about the same as 1G once it becomes practically standard on all new chipsets and motherboards.But for a small amount more (the prices are coming down quite a bit now on 10GbE gear) you can future-proof and have a 10GbE switch ready for some day replacing wires, or for using on the shorter runs.
Also, "future-proofing" has very subjective value. If I bought a 10GbE switch today, it will likely cost me more in additional power over the years that I only have it for "future-proofing" than its replacement will cost to buy by the time I may actually need it.
@revjim23
Thank you for providing link (missed it on your first post).
Checked price for TL-SX105 and is about 224GBP ("coming soon"). Mmm.. that's about 250-260€ (=US$). Yes, is affordable, but not that cheap either (for a switch). On the other hand, if 2.5G/5G switch cost 130$, then 10G sure looks better deal. And we will probably moan about "too expensive" anyway.
As mentioned in my previous post, I hope we will see high speed routers soon too -just to avoid having a lot of devices and cable sallad.
Anything new starts with a substantial early adopter premium while there is almost no existing install base. 2.5GBase-T has a huge handicap over 10G there but its compatibility with existing wiring will ultimately win the battle by providing corporations with an obvious upgrade path for their office fleet that does not require ripping tons of wiring. 1GBase-T used to be ludicrously expensive too and now you can get 8-ports switches for $30, cheaper than any 100Base-TX switch I have ever bought. Mass manufacturing trumps nearly all else.1G switch = $20
2.5G switch = $130
10G switch = $250
The middle path doesn't make any sense here.
Motherboard manufacturers are integrating 2.5GbE in increasingly lower-end boards as the incremental cost over 1GbE goes down, same will happen with switches as demand goes up. Give it a few years and 2.5GbE switches will become dirt-cheap too.
The "early adopter" premium in this context isn't a matter of time, it is a matter of millions of new ports deployed - companies have no incentive to cost-optimize higher speed equipment until volume rises enough to justify the R&D expense. The cost of 1GbE didn't come down much until corporations rolled out GbE in their offices by the millions of ports annually and 2.5GbE offering a plug-and-play upgrade path is in a much better position to be the next standard to achieve that.The spec for 10GbE over twisted pair copper was published in 2006 (802.3an) and the early adopter premium has been paid for 15 years. We're now entering the cheap phase where the prices come down.
More affordable sure. Still nowhere near as cheap as 1GbE which is down to $3 per port and that's where I expect 2.5GbE switches to race down to in relatively short order.And now TP-Link is selling the TL-SX105 for around $50 per port. Premium? I dunno, but I call it reasonably affordable.
Also don't forget that each 10GbE port you want to use also requires a 10GbE adapter and those still cost $150+ a pop whereas 2.5GbE cards could already be bought for under $40 at launch two years ago, can now be found for as low as $25. Additionally, the incremental cost of 2.5GbE over 1GbE has become low enough that manufacturers are including 2.5GbE across 80% of their newest motherboards based on NewEgg listings for single-LAN Intel 500-series motherboards: 115 boards with 2.5GbE vs 27 boards with only 1GbE.
As far as the consumer space is concerned, 10GBase-T(v1) is about to get BetaMax/HDDVD'd.
That is only true if all five computers attached to the switch are attempting to access something at full speed at the same time. In the real-world, that hardly ever happens. In a consumer setup, it will practically always be just one person dumping or retrieving something at any given time and maybe 100Mbps going off to smart TVs streaming raw BD rips.In that case if your switch is 2.5GbE all four client devices are sharing that 2.5Gb of bandwidth connecting to the NAS, so roughly 625k of theoretical bandwidth per client.
Yeah, you are correct for a consumer setup. If a consumer goes that far it's probably for bragging rights.That is only true if all five computers attached to the switch are attempting to access something at full speed at the same time. In the real-world, that hardly ever happens. In a consumer setup, it will practically always be just one person dumping or retrieving something at any given time and maybe 100Mbps going off to smart TVs streaming raw BD rips.
