I've read so many reviews/forums, I've officially confused myself. Please give me some advice. I want to spend as little as possible to cover my needs (obviously) but also have a system that won't be outdated too soon.
I'm going with the 6350 and 8gigs 1600ram. Is that fast enough ram?
I already have a 600w power supply, case with fans and cpu cooler, and 3tbs HD space with OS.
I'm looking for a 40" 1080p LED HDTV for my main monitor and my acer 19" monitor as a second.
I don't have cable service, I either download or stream video on my main monitor and use the second for web browsing, etc. I'm also a musician/film maker and use the newest available versions of Protools, Reason, Adobe Premier, Soundbooth, etc.
I'm hoping for suggestions on motherboards and videocards for what I've described and also suggestions for adding gaming at different settings.
A problem I'm running into is finding a motherboard that is compatible with the 6350 out of the box, without a bios flash.
I live in Sarasota FL. There's no MicroCenter near me so all parts need to be available online. I'm not picky as far as what site.
No overclocking, SLI, Crossfire...
I'm not locked into any specific amount, but a mobo under $100 and GPU under $150 would be best.
Thanks.
Thanks.
