Cheap as possible PC Build help
Jake1781
41
i am looking to build a pc for a cheap as possible for my friend to use when they come over to game, im looking for some help as i dont have the knowledge to find the best out of the cheapest parts, my budget is simply as cheap as you can possible get it, this pc only needs to last around 2 years at most and run games such as GTA V etc... on around medium settings will be good enough. the main sort of games will be games such as dead by daylight and the forest. Upgradeability is not needed! As im trying to keep costs down if you think an AMD CPU is the best option then im happy with that.
I will not need an OS in this budget nor will i need a mouse or keyboard, i will buy a monitor after i have built the pc. i hope this is enough information to help.
Thankyou in advance!! for all the help!!
Jake.
Niklas_13
3,245
199
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor (£106.99 @ Aria PC)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard (£62.25 @ CCL Computers)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory (£49.33 @ CCL Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£45.78 @ Misco UK)
Video Card: Gigabyte GeForce GTX 1050 Ti 4GB Video Card (£144.26 @ CCL Computers)
Case: BitFenix Nova ATX Mid Tower Case (£26.99 @ Aria PC)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply (£51.95 @ Overclockers.co.uk)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£13.49 @ Ebuyer)
Total: £501.04
Generated by PCPartPicker 2017-01-08 01:12 GMT+0000
Jake1781
41
try and keep below £400 if possible and i will buy the OS outside of the budget for the hardware
Niklas_13
3,245
199
Total: £501.04
alth0triplemadang
636
111
A good key is a "legit" key
