cheap graphics card that will run BF4 on medium 60fps Help ME please
cl0udedmind
5
I just bought battlefield 4 and i cant really play the game all too great i have everything on low but it plays really BAD haha guess i should have read requirements. I just thought if i could run BF3 on medium i would be able too run BF4 on low...yeah not the case so i'm looking too get a new graphics card i don't need too play on ultra would prefer too play on medium or high with 60fps.
I don't know anything about computers so im looking for help here are my computer specs
processor-intel core 2 duo e8500 @3.16Ghz
RAM-4 GB
operating system-32bit windows 7
current graphics card-geforce gts 450
and my monitor is a 24inch 1920x1080
i have a 650 watt power supply and i got about $150 i set aside too spend
thank you for the link and i have a 650 power supply i dont know if that is good or not im assuming its okay right?
260x or 750 Ti would probably be your best performance bet, you will see a combo of med/high at 60 fps. Would be a pretty good setup :)
Thank you big help one more thing i dont knwo what SLI is mind explaining and when i bought my comp he was telling me how i can overclock my comp i dont plan on doing it just want too know a little more
thank you thank you ill be looking into these and if you can explain SLI and overclocking i dont plan on overclocking just want too know
Overclocking is way too much to explain here lol
Sli is adding another same gpu to your setup to theoretically double performance. What it does is use both cards simultaneously to process the graphics. Games have to be optimized for sli compatibility, so you see anywhere from 90% gains, to actually decreasing performance with it. Generally it's a positive though. The 750 ti allows for sli in the future if you go that route. Your motherboard will have to support it though
Actually a Radeon 7790/R7 260X would suffice. They are cheaper than the GTX 750 Ti, and somewhat faster. Unless you have a really crap PSU, you should go get a 7790/260X
