Discussion CHEAP MESH WiFi System
N7AS
4
I am thinking to upgrade to a Cheap MESH WiFi System.
Right now I am using a NETGEAR R7000 Nighthawk WiFi Router.
My main requirements for a New MESH system are:
Ability to Disable SIP ALG. I need this so my VOIP phone system will work properly. (Without this I will only get one-way audio.)
Ability to Reserve the IP address of devices.
Set DNS Servers to other than default such as 8.8.8.8 and 8.8.4.4
I need to set SSID to the same as my present router.
I would either add the MESH system to my present router or Purchase a new MESH system
Here are some that I have been looking at:
MESH WiFi Systems
TENDA MW-3 3-Pack - $92.90
TENDA MW-6 3-Pack - $129.97
WAVLINK Halo Base 3 - $129,99
Bearifi BearExtender Edge Mesh 802.11ac Wi-Fi System with BearExtender - $59.00
TP-Link Deco Whole Home Mesh WiFi System 3-Pack - $139.00
TOTOLINK T6 AC1200 Dual-Band Whole Home & Mesh Wi-Fi System 2-Pack - $79.99
Oh, Did I mention CHEAP?
Why do you want mesh in the first place. Exactly what feature do you think they give you.
Mesh in general is just a different name for a repeater/extender. Some but not all so called mesh systems use a slightly different method to repeat the radio signal. They still all suffer from the main problem is you now have 2 radio signals that can be interfered with or damaged.
You should never use a repeater unless there are no other options. You are trading performance for coverage.
