[SOLVED] Cheap ups to make "clean" power
sloan1209
80
I've gone through 3 UPSs over the last year and a half or so. I'm starting to think that I might have dirty power in my house? Cant think what it could be. Is there a cheap solution to plugging my computer into safe and clean power?
"Clean" power independent of the mains power requires a "double conversion" UPS. They are not cheap. I recommend buying used commercial UPS units on E-Bay. Buy them WITHOUT batteries if possible to save shipping costs. Then buy new batteries. The APC Smart-UPS Online are all double conversion units. A 1500VA unit is around $300 used. As I said, not cheap.
sloan1209
80
how do you gone through 3 ups? what happened to them?
what the brand and model?
I've been using EVGA bronze ones I believe 750w. It's the only thing I can think it is. Each time, I start to get random sudden shut downs. Last time I replaced it, it started to work fine again. Last couple days it's started to happen again. Last night it shut down and TRIED to turn back on 5 times but only slightly "wirr'd" each time before it fully came back. I don't know what else to point the finger at. I also replaced my MOBO last time it happened so it's now that. I've seen other posts say that the power coming out of the wall can be "bad" somehow
kanewolf
