I have found a few deals on CPUs and motherboards. One was the ryzen 5 1600 with the ASUS Prime X370 Pro. The other was the ryzen 5 2600x with the ASRock AB350 Pro4. There is only a 10 dollar difference between the two in the deals I'm looking at. Can anyone help me figure out which would be better to get? This setup will likely be used with a gtx 1060 6gb and a 75hz monitor, if that helps the decision.
Thank you.
Thank you.
