Cheapest Budget Gaming build with low electricity consumption 2011
zealotz
176
APPROXIMATE PURCHASE DATE: June 1
BUDGET RANGE: 230-270 Before / After Rebates, but playable in all latest games on decent settings.
(my build @ $231.96)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:Gaming, surfing the net.
PARTS REQUIRED: Processor, Motherboard, RAM and Graphics card only.
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, ncix.com -- to show us selection & pricing
COUNTRY OF ORIGIN: Philippines
OVERCLOCKING
: No SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1440x900, 1600 x 900 or 1920 x 1080 (from 19”, 20” or 21.5” preferred brand Samsung). ADDITIONAL COMMENTS: low electricity consumption is very important.
1. Low cost gaming builds, but can perform gaming my target is all latest games playable on decent settings at a MONITOR RESOLUTION of 1440x900, 1600 x 900 or 1920 x 1080. Plus Cost is important cause I need 200 units of gaming pc.
2. Durable parts for heavy usage like 15 to 20 hours a day.
3. Less Electricity consumption.
4. The gaming build should be cool no fans needed just one built in auxiliary fan.
5. Motherboard that can withstand frequent brownouts, cause in my country brown out happens almost twice a week.
AMD Athlon II X3 450 & BIOSTAR A880G+ AM3 AMD 880G HDMI Micro $129.98 ] http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.625653&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=[/url]
Kingston 2GB DDR3 SDRAM DDR3 1333 (PC3 10600) $21.99 ] http://www.newegg.com/Product/Product.aspx?Item=N82E16820134812 [/url]
HD 5670 $79.99 ] http://www.newegg.com/Product/Product.aspx?Item=N82E16814102923 [/url]
Total: $ 231.96
Gaming build post 1
if anybody can suggest a gaming build that can beat this one please post any help would be much appreciated. Thank you in advance....
Thanks for this suggestion i also saw this before i3 is good in gaming right now but there is problem most of the games right now is Gpu intensive not cpu the Athlon x3 450 can handle all of the games to well without any problem even running in 2 gb ram plus hd 5670. I think all games is playable in moderate settings, plus i can save big money. Because I'm buying 200 units of gaming PC but thanks i will consider this option if prices of i3 will go down next month.
[url Intel Core i3-2100 & ASUS P8H61-M LE/CSM $189.98 ] http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.631850&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3899435&SID=skim1402X558040X88b95f2ccf7b82e05042d76785c2f55e [/url]
my build
Your cpu and mobo cost: $189.98
mine cpu and mobo cost: $129.98 my savings 189.98 less 129.98 = $60.00
do you think its worth it? Any of you guys can give comment on this, any help would be much appreciated.... thanks :)
Thanks for this suggestion i also see this before but there is problem most of the games right now is Gpu intensive not cpu the Athlon x3 450 can handle all of the games to well without any problem even running in 2 gb ram plus hd 5670. I think all games is playable in moderate settings, plus i can save big money. Because I'm buying 200 pieces but thinks i will consider this option if prices of i3 will go down next month.
[ur Intel Core i3-2100 & ASUS P8H61-M LE/CSM] http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.631850&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3899435&SID=skim1402X558040X8f7677516913c0aa4eb0941dd45d4e93 [/url]
my build
i will be getting 200 units so $60 x 200 = $ 12,000.00
are you sure this is better than HD 5670 can you give me a site with benchmark please.... thanks
Imo, it's well worth the $60. The performance alone is worth $60. It also uses less watts and has a future upgrade path. AM3 really does not have an upgrade path.
Obviously your title says "Lowest electricity comsumption". Well not only is it a lot faster but it uses 30w less.
Oh my your right i can't believe what i saw, how is this posible 4 vs 5 series :) but the electricity load power 5670 is better hmmmm now it depends on the price per unit..... i will compute which one is better.... by the way thank you very much :)
