Cheapest build for i5 8400
Jul 25, 2018
11
Hi! I am totally new in current pc build. Previously I am using i5 2500k, and still in love with it. but unfortunately it was killed by my house power failure.
Therefore, I would like to build a new PC base on i5 8400. The cheapest possible.
Mainly for gaming
No overclocking, no sli or crossfire, better onboard sound, no fancy led and cheapest possible
Planning to get 16gb ram, but need help in which speed to choose
Planning to get Maxsun RX580 8gb, not a famous brand, but it's the cheapest. But worry about bottleneck problem on i5 8400. Previous GPU is just hd6850
Planning to get Asus - TUF B360M-EGAMING, but the onboard sound is ALC887, prefer better sound if possible
Will use back current cooler master 750w PSU if possible
Heatsink will use back cooler master 212 evo
Budget?
Country?
Best not to build based on price alone or you will have issues, that is a guarantee 100%. What you will end up with is an unstable piece of garbage and or one that won't last very long.
Something for nothing just doesn't happen when it comes to PC parts, quality is important.
You get what you pay for, that is the bottom line, there is no way around that, no shortcuts etc.
Best to scrap the old PSU and get a new one (High quality unit) as it's suspect due to the power failure, your pc was killed and the PSU didn't protect it.
Killed by power outage or failure?
Make this as a lesson learned. For the next PC, make sure you buy a good UPS (usually already equipped with everything you need to protect the PC from over-voltage/surge, blackout, etc.).
Just make sure the UPS has can buy you enough time to properly shutdown your PC and it delivers pure sinewave (pure sinewave is to avoid issues with some PSUs).
Budget?
Country?
Budget as low as possible
Country Brunei
Will change PSU also if PSU also having problem. But can't be sure at the moment. I did tested it with paperclip, it seem running fine
My problem is when I turn on the pc, all the fans running fine, but failed to start up the pc and in boot loop situation.
At the moment planning to get
Motherboard
MSI - H310M PRO-VD Micro ATX LGA1151
Even the onboard sound ALC 887, but gonna live with it, as it's cheapest I can find
RAM
G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2400
Will add another 8gb in the future
Graphic card
Use back old HD6850 and will get a better one in the future
It's due to my budget problem, but in need of a pc
