Cheapest Graphics Card for Triple Monitors for my Setup
Glutz
19
Hello,
I really need a third monitor for video editing and work. I only game a little bit and when I do its only on a single monitor. I want to know what the cheapest GPU would be that would allow me to use three monitors. All feedback is appreciated.
Here are my specs:
AMD A8-7600 3.1 GHz Processor
8 GB DDR3 RAM
1 TB 7200 rpm Hard Drive
Integrated Graphics
Windows 10
if you need more info on the pc here is the link: https://www.amazon.com/gp/product/B011HNTG62/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
What gpu could I use?
Thanks so much
Edit: I was considering this https://www.amazon.com/MSI-GAMING-GTX-960-4G/dp/B00V4HY522/ref=sr_1_2?s=electronics&ie=UTF8&qid=1498835712&sr=1-2&keywords=gtx+960
If 1080p monitors, then any cheap GPU is fine. Do you know what PSU that computer is using? The Amazon site has no info on it.
EVGA GT 710 is available for < $50. The PSU should be fine, but it's worth double checking.
I highly doubt your power supply can handle the card that you linked to.
My power supply is 450w
Are there any gpus in the $100 area?
And would i need splitters for the EVGA GT 710
Wattage isn't the most important stat of the power supply. The GT 710 should suffice for triple monitors. It's not great for gaming, but the A8 is already going to bottleneck the build if you're going to hardcore game on it.
There are other GPUs around $100, but it's not really worth it if you just need triple monitor support. If you want one for also gaming, then GTX 750 Ti is an option.
The GT 710 is plug and play. The GTX 750 Ti may require one 6-pin PCIe power connector.
