Cheapest motherboard for i5-8400 and i5-8500
Jul 24, 2018
I want a motherboard which is cheap and compatible with i5-8400
And is there a huge difference in performance btw i5-8400 vs 15-8500 ?
What is it that you plan on doing with this system?
The really cheap boards are very limited and ment for basic workstation computers.
If you plan on gaming on this system I would recommend getting a higher grade MB. The higher grade boards have more and better power phases and capacitors for better stability.
