L Leon_110 Distinguished Jul 27, 2011 3 0 18,510 Jul 27, 2011 #1 Is there like a computer app I can check signal strength of Cat5 ethernet signals while it is actually communicating?
Solution calmstateofmind Aug 7, 2011 What you're looking for is something like this. You'll probably have to order one online, or if there's a Radioshack around your area they should have one. A computer store as well might...
PhilFrisbie Splendid Apr 22, 2006 6,472 3 26,465 Jul 31, 2011 #2 No. That information is only useful to the hardware; either the signal strength is good, or it is not good. Upvote 0 Downvote
L Leon_110 Distinguished Jul 27, 2011 3 0 18,510 Aug 7, 2011 #3 Is there anyway at all to test signal strenght? Upvote 0 Downvote
M MysticMiner Distinguished Aug 3, 2011 352 0 18,810 Aug 7, 2011 #4 Yes, you can get a cable tester for under 20 bucks. Check local hardware stores if you don't want to order one online. Don't spend hundreds on one, there are testers of that quality, but you don't need it at home. Upvote 0 Downvote
calmstateofmind Distinguished Jul 2, 2009 898 0 19,210 Aug 7, 2011 Solution #5 What you're looking for is something like this. You'll probably have to order one online, or if there's a Radioshack around your area they should have one. A computer store as well might... Upvote 0 Downvote Solution
L Leon_110 Distinguished Jul 27, 2011 3 0 18,510 Aug 17, 2011 #6 Best answer selected by Leon_110. Upvote 0 Downvote
PhilFrisbie Splendid Apr 22, 2006 6,472 3 26,465 Aug 18, 2011 #7 Yes, that breakout adapter will allow you to connect to a live Ethernet cable, but you cannot simply connect a volt meter to it and measure the signal. You might be able to do it with a high impedance oscilloscope to see the signal peaks. Upvote 0 Downvote
