check it out please first build need expertise
Jacob19
33
This is my first build and I'm not planning on overclocking just play games in spare time and Im planning on playing this on a 30 some inch TV and i already have the operating system covered.Just checking before buying,Does all of this match up and will it be able to play on high on BF4 or Day z? will Everything fit?
AMD FX-6300 3.5GHz 6-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Asus M5A97 R2.0 ATX AM3+ Motherboard
G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1866 Memory
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
MSI Radeon R9 280 3GB TWIN FROZR Video Card
Cooler Master HAF 932 Advanced ATX Full Tower Case
Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply
HP DVD1265I DVD/CD Writer
In a Mid Tower, yes, you have plenty of room to fit a standard amount of computer components.
A Full Tower is pretty big, and will have lots of extra space for expansion or custom watercooling loops, none of which you seem to be looking for. In your circumstance, I think it would not be most beneficial for you to get a Full Tower.
You should buy the RAM as a kit like this http://www.newegg.com/Product/Product.aspx?Item=N82E16820226395&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
