Check out my system need help ASAP!
yaro1996
I have a custom PC with q9550 2.83ghz york field ,Galaxy GeForce GT 520 1GB 64-bit DDR3 video card ,g31t-m motherboard with 4gb of ram clocked at 400mhz, 700gb hard drive 7200rpm, recently i was messing with the bios and ps/2 ports and usb ports stopped working so now im thinking of getting a new motherboard and new ram what would you guys suggest i get im on a budget so not to expensive i dont OC, i would like the motherboard to have ddr3 ram and pci-express 2.0.
If you plan on keeping that processor, you're not going to have that many options with motherboards because it's socket 775. You can still get a few new boards though. Here is what Newegg still sells.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007627%20600007879&IsNodeId=1&name=LGA%20775
They're basic, but they'll get the job done. I don't think I'd bother upgrading the ram, but make sure you get a board with the proper ram specifications. They have DDR, DDR2, and DDR3 for those boards. If you do want to upgrade, go with 8Gb of DDR3.
