Check signal cable [SOLVED]
Storey
29
Hei guys, so yesterday i only removed my graphic card out to clean the dust of the fans. And after that i puttet it back in everything worked and today i was trying to start the computer and it only showed chech signal cable on the screen. So i have no idea what to do my graphic cards fans are turning,tryed to remove the batterie for 5mins still didint work. If anyone knows how to fix it please help me because i need to do some importent things
Thanks for answers have a nice day!
Did you also reseat GPU as well? If you have integrated graphics, try using then to see if your monitor shows proper signal. If it does, you will be sure its something about your GPU
Well i plugged in my cable to my lapyop and changed the screen and now i van see that it works so it was problem with the cable that was going from graphic card to pc screen thx for the answer guys
