[SOLVED] Checking rgb fans with only power supply and motherboard?
Feb 16, 2019
I’m currently building my first pc and only have the following parts- Corsair spec alpha (case) Asus tuf b450m plus(motherboard) and Corsair cx 650 (power supply)
I’d their any way I can see if the built in rgb fans work? I’ve tried but can’t figure it out.
Thanks in advance
I'd say: No.
Minimum you'll need would be: CPU, MoBo, RAM, PSU. <- with those, you can boot to BIOS and test if the fans spin.
Btw, Spec-Alpha doesn't come with built-in RGB fans. What it comes with is single color LED fans,
specs: https://www.corsair.com/us/en/Categ...r-ATX-Cases/spec-alpha-config/p/CC-9011085-WW
Spec-Omega RGB is the one that comes with built-in RGB fans,
specs: https://www.corsair.com/eu/en/Categ...Carbide-Series-SPEC-OMEGA-RGB/p/CC-9011140-WW
Thanks!
