My new dell laptop came with the 64 bit version of windows 7 home premium. I have several programs that will not run with the 64 bit software (Tuneclone is one) can I change it to 32 bit?
Most programs that wont work on Win 7, the problem is Win 7 (or 8) itsself. Some older programs simply wont run on the new win 7 kernel. There is xp mode you can try too. The problem is not the 64 bit part. If the program wont run under 64 bit windows, it most likely will not run on the 32 bit version either.
