Greetings
I got some problems of my pc, 2 days ago i got my pc automatically reboot then im went to event viewer to check it out and found error event id 1001 bugcheck,for the first time im just ignore it, then several minutes while im scanning my pc with win def and malwarebytes it going reboot again with same problem, yeaterday im get same issue again, memory diagnostic, sfc scan,virus scan not found anything, using ccleaner found a large temp file (1,5gb),today i try chkdsk, chkdsk /f /r c🙁ssd) successfully, but on d:\ (hdd 2tb seagate) is stucking at 10% alr passed 3 hours (never happened before when im chkdsk my drive D:\ lastime) what should i do? I have no idea
Im using windows 10 pro x64
Every answer I'll appreciate it need help ASAP
Thanks
Thanks
