Abhishek779 :
i have these three choice please suggest which is better value in these motherboards i have listed the prices according to cheapest i could get in my country
1 gigabyte ab350 gaming 3 - 135 dollers
2 asus strix b350 f - 155 dollers
3 msi x370 sli plus - 156 dollers
4 gigabyte ax370 k3 - 165 dollers
other then these motherboards every motherboard in my country is bit of an overpriced (india)
I would
eliminate the
Gigabyte AX370 Gaming K3 on your list for the following reasons: 1) Despite having an X370 chipset, it does
not support SLI like most other X370's do, 2) It only has
7 (4 + 3) power phases which is similar to B350 mobo's, and 3) It is the
most expensive among your four shortlist of mobo choices.
Now, for the remaining three motherboards:
Gigabyte AB350 Gaming 3,
Asus ROG Strix B350-F Gaming, and
Msi X370 SLI Plus, choosing any of the aforementioned mobos, you will get these
similar features:
All have
6x SATA ports and
1x M.2 socket for your storage devices
All have
4x RAM slots supporting
up to 64GB capacity and
more than 3200MHz speeds
All have
3x PCIe x16 slots (but has different modes/speeds), with
2x having reinforced slots
All have
5x to 6x 3.5mm audio jacks at the rear panel
All have
2x internal USB2.0 (9-pin) headers (supports up to 4x additional USB2.0 ports)
All require a
24-pin ATX power cable and an
8-pin ATX12V/EPS power cable
All support
overclocking the Ryzen CPUs
All are
ATX in size (with slight differences in widths)
What sets these three motherboards apart, and what you might consider one with the best value, depends on the specific features and ports/connections that you want and need, based on these
salient differences:
POWER PHASES:
Gigabyte has
7 (4 + 3) |
Asus has 8 (4 + 4) |
Msi has
10 (8 + 2)
90-DEGREE ORIENTED SATA PORTS (for better cable routing)
Gigabyte has
2 out of 6 |
Asus has
6 out of 6 |
Msi has
6 out of 6
PCIE X16 VERSIONS AND SPEEDS:
Gigabyte has
1x PCIe3.0 + 2x PCIe2.0 at [x16/
x4*/
x1] (*at [x2] if some PCIe x1 slots are used)
Asus has
2x PCIe3.0 + 1x PCIe2.0 at [x16/x0/x4*] or [x8/x4/x4*] (*shared with some PCIe x1 slots)
Msi has
x8/x4*] (*shared with all PCIe x1 slots)
MULTI-GPU SUPPORT:
Gigabyte may only support 2-Way AMD CrossFire (depends on PCIe2.0 x16 speed and PCIe x1 usage)
Asus always supports 2-Way AMD CrossFire and may support up to 3-Way CrossFire
Msi always supports 2-Way Nvidia SLI or 2-Way AMD CrossFire and may support up to 3-Way CrossFire
PCIE2.0 X1 SLOTS:
Gigabyte has
2x PCIe x1 slots |
Asus has
3x PCIe x1 slots |
Msi has
3x PCIe x1 slots
LAN CONTROLLER:
Gigabyte uses
Realtek RTL8111G |
Asus uses
Intel I211AT |
Msi uses
Realtek RTL8111H
AUDIO CODEC:
Gigabyte uses Realtek ALC1220 |
Asus uses
Supreme FX S1220A |
Msi uses
Realtek ALC892
USB PORTS AT REAR PANEL:
Gigabyte has
7x total (2x USB3.1 Type-A + 4x USB3.0 Type-A +
1x USB2.0)
Asus has
8x total (2x USB3.1 Type-A + 4x USB3.0 Type-A + 2x USB2.0)
Msi has
8x total (1x USB3.1
Type-C + 1x USB3.1 Type-A + 4x USB3.0 Type-A + 2x USB2.0)
INTERNAL USB3.0 (19-PIN) HEADER:
Gigabyte has
1x |
Asus has
1x |
Msi has
2x
FAN HEADERS:
Gigabyte has
5x total |
Asus has
6x total |
Msi has
6x total
RGB STRIP (4-PIN) HEADER:
Gigabyte has
1x |
Asus has
2x |
Msi has
1x
I/O SHROUD/ARMOR:
Gigabyte has
none |
Asus has
none |
Msi has
an I/O shroud/armor
LED AMBIENT LIGHTING:
Gigabyte has
RGB ambient lighting |
Asus has
Msi has
none
COLOR/MOTIF:
Gigabyte is
Black + Red |
Asus is
Gun Metal + Black |
Msi is
Black + Gray
So, with the above differences in features, specs-for-specs, the
Asus and Msi are definitely better than the Gigabyte.
I would personally get the
Asus ROG Strix B350-F Gaming for its better LAN and Audio codecs, Fan Headers, USB ports, RGB Strip headers, and layout/looks/aesthetics as the rest of the ports/connections are suitable for me (I won't do SLI nor CrossFire anyway). However, it is your call, based on your own personal preferences, needs, and budget constraints if the ~$20 price is worth it to get either the Asus or the Msi. It's up to you which one to choose based on what features you will prioritize.
