Last updated February 2017
If you know what to look for, quality power supplies can be found from other manufacturers. The new EVGA SuperNOVA series, for example, uses the new Superflower Leadex platform for the OEM which is extremely high quality. If you do not understand anything about power supplies, ask someone knowledgeable. Another thing to note, do not buy into the marketing. For example, Corsair has several good series, although that does not mean all of them are good quality. The CX, CS, and VS series are all lesser quality and should never be used in a high-end machine, although they are okay for office machines. Most people are not even aware that Corsair, and indeed most manufacturers, do not build their own power supplies. Their lower end models are generally from the likes of Channel Well Technology (CWT) while higher end models are Seasonic. Their flagship, the AX1500i, is a Flextronics based model of whom typically only make PSUs for servers which must be run in harsh conditions 24/7.
A lot of people will look at the efficiency on the PSU's sticker to decide which power supply to buy. This is bad practice and should not be done except when already comparing quality units! The ABS Majesty MJ1100-M is a gold rated power supply but it is a very poor unit. It is way out of spec when at load and is vastly overrated on wattage. 80+ certification is achieved by sending a single test unit to the 80+ lab. This means that a company can hand pick their best performing unit to skew results. The lab is also much cooler than your average PC case will get which tends to skew results as well. For a more comprehensive explanation, visit the link at the top for [H]OCP. Finally, efficiency only really matters when comparing quality units. The EVGA SuperNOVA G2 1000W is less efficient than the EVGA SuperNOVA T2 1000W. One is rated for Gold certification and the other is rated for Titanium certification. Both are highly regarded units however, with the only differences being the miniscule operating cost differences and slightly different heat output of these units.
Does the weight of the unit have anything to do with quality?
I was just recently asked this question but like the efficiency question it doesn't have a definitive yes or no answer. A junk unit may be heavier than a non-junk unit. For weighting to really matter, you really need to be comparing two units that are very similar. In general, heavier units may be better than lighter units, but there are plenty of exceptions to the rule. I'd much rather be running a 350W Seasonic than a 1050W CoolMax PSU for example.
Why should I spend so much money on a PSU?
Power supplies are often overlooked and an afterthought when builders are choosing which components to use in their latest build. Power supplies are the most important component in your entire build. If you use a cheap power supply from the back of a white van, expect your other components to suffer for it. Cheap units often have out of spec voltage, out of spec ripple, and poor PFC if it exists at all. These cheap units will use the cheapest electronics one can find, often using questionable capacitors and bad soldering. If these units even have a warranty, they will likely be for one year, and the company may not even exist when the unit does die. On the other hand, a quality unit can last you a very long time. The EVGA SuperNOVA G2/P2/T2 series all have a 10 year warranty! Not only can you continue using this PSU for every build for the next 10 years, the quality control is much more substantial. The voltage is right on point, the ripple is almost non-existent, and the PFC is top-quality.
What happens if a power supply dies?
In general, a power supply will quietly take its last breath before never turning on again. This is true of most OEM units that come with your pre-built computer and for most enthusiast units. Occasionally, especially on junk units, a power supply can take other components with it. That $400 graphics card or $300 processor is no longer usable because you only wanted to spend $30 on a PSU instead of $80. In the worst case scenario, a power supply can catch on fire and burn up your PC and maybe even the rest of your residence. This is why it is very, very important that you do not skimp out on a power supply. Do not attempt to repair your PSU, throw it away! The only people who should attempt a repair on a power supply are those who work with electrical components as a career.
How much wattage do I actually need?
Probably not as much as you think. Most modern processors and graphics cards will get by on 450W just fine. A top of the line system that is heavily overclocked with one GPU will usually be fine on 850W, perhaps 1000W if you are overvolting. The only reason you should get a PSU over 1kW is if you are planning to run a machine in SLI or Crossfire. For a simple and easy to use calculator I recommend the eXtreme calculator hosted at outervision.
The units listed below are all fully modular. At the time of this listing they were the quality units with the lowest price available from Amazon. All of them are competitive and have a great price paired with great performance.
Foreword
I often see questions about power supplies, therefore, back in May of 2014 I started making this guide which I have kept periodically updated on my own. My guide has remained mostly unchanged up to this point with the addition of a few manufacturers and fixing up the structure a bit. The guide below is the latest edition.Links to Useful Info:
■A story of the dangers of cheap PSUs
■A non-exhaustive guide to selecting a power supply
■A list of most major PSU manufacturers which includes OEM, reviews, etc.
■The best PSU reviewer on the internet
■Review of a "bronze" rated Raidmax
■[H]OCP: Why 80+ certification is meaningless
Introduction
There are many considerations to take into account when purchasing your new PSU. A poor selection of PSU is not only dangerous for your computer, but dangerous for your own safety as well. A cheap power supply can easily destroy your computer and/or catch on fire. An exploding PSU that catches fire can be deadly - it releases toxic smoke and can catch your entire residence on fire. There are a few manufacturers which I can recommend that have quality units (with isolated exceptions). These are:What Does All of This Mean?
Don't look at the brand on the label, look at the OEM. This means that I will often recommend a unit that is not from my list above. The Lepa G1600-MA is a rock solid PSU and it is an Enermax unit. The NZXT Hale90 850 is a Superflower unit. Superflower is a very good OEM, and any of their platforms after 2012 are very competitive with Seasonic, Etasis, Delta, etc. FSP is another OEM with good platforms as long as you get one of their high-end platforms like the Aurum series. So what makes one OEM better than another? Many things are considered, but nothing makes one OEM inherently better than another. CWT, for example, is a decent OEM if they are given the money to make a good platform. In the case of the Corsair CX series, for example, Corsair just wanted a cheap platform that they could relabel and sell. This build quality begins to show when you look at the insides of it. The primary capacitor for this platform is Capxon and the secondaries are Samxon. These are not first-tier capacitors and are not intended to be abused like they would be by a high-end machine. Yet, for the EVGA SuperNOVA G2/P2 series, EVGA worked with Superflower to build a strong platform. This quality again shows when you look inside - it is a very strong platform capable of running a high-end system.FAQ
How does efficiency factor into all of this?A lot of people will look at the efficiency on the PSU's sticker to decide which power supply to buy. This is bad practice and should not be done except when already comparing quality units! The ABS Majesty MJ1100-M is a gold rated power supply but it is a very poor unit. It is way out of spec when at load and is vastly overrated on wattage. 80+ certification is achieved by sending a single test unit to the 80+ lab. This means that a company can hand pick their best performing unit to skew results. The lab is also much cooler than your average PC case will get which tends to skew results as well. For a more comprehensive explanation, visit the link at the top for [H]OCP. Finally, efficiency only really matters when comparing quality units. The EVGA SuperNOVA G2 1000W is less efficient than the EVGA SuperNOVA T2 1000W. One is rated for Gold certification and the other is rated for Titanium certification. Both are highly regarded units however, with the only differences being the miniscule operating cost differences and slightly different heat output of these units.
Review of a 350W Bestec PSU
Disassembly - 7 March 2014
I had an old Bestec laying around that I felt like ripping apart. Below is the results of what I found.
The Bestec looks like your standard OEM power supply. Nothing fancy, but I've definitely seen better and worse. Already weary though, as this PSU does not have active PFC. You can tell because it has a voltage regulator switch on the back. Cooling may be adequate for a 350W, but I'd still rather see a bottom mounted 120/140mm fan. None of the cables are sleeved but they are all 18 AWG. Outer casing is flimsy, which is another sign of cheap components.
An initial teardown proved more difficult than expected. In this image we see the AC line filtering and the two primary side capacitors. These are Capxon, and they could be worse. The filtering is done by two coils, two X capacitors, and two Y capacitors. Not bad for a cheap 350W unit.
A closer look at the primary side.
The secondary side capacitors are also Capxon. Could be worse as before. Really wish they would do something with that mess of wiring there. Ferrite coil is separated by a plastic shield.
I did not have the tools to remove the heatsinks at the time of this review, so I am not able to show pictures of the Schottky bridge rectifiers. The board looks like the same one used by higher wattage models, as there are several labelled spots which are missing components of any kind. D6, R102, Q17, SCR1, etc.
I did not have a soldering iron and desoldering tool at my disposal so I simply cut the 20 or so wires to get the board out.
The soldering job here isn't terrible - not the best, but not bad. The complaint I have here is that it is barely labeled at all.
Final Thoughts
While I would never put a Bestec in my personal computer, it isn't terrible for an OEM. I've seen much worse when it comes to power supplies. This was pulled from a low-end HP. I was never worried about turning it on while I had it.
Final Thoughts
My Recommendations by Wattage (February 2017)
■200W-450W: Silverstone Strider Gold 450W[/*]■500W-650W: EVGA SuperNOVA GS 550W[/*]■700W-850W: EVGA SuperNOVA G2 750W[/*]■900W-1100W: EVGA SuperNOVA G1 1000W[/*]■1150W-1400W: Seasonic SS-1250XM 1250W[/*]■1450W-1600W: EVGA SuperNOVA 1600 G2[/*]
