Hello
I bought a zalman z3plus case for my build a few months ago and i am very pleased with it, however, the quite Led fan that comes pre-installed at the front seemed to pull next to no air into the case, i even tried a stock antec fan from another of my cases but but there was still very little airflow.
on closer inspection, i found that the fan filter on the front panel is essentially 3mm of black sponge making it hard for the fans i had tried to pull in a sufficient amount of air while staying reasonably quiet.
My question is, What would be the best fan for my case?
The two fans i have considered so far are the Corsair SP 120:
http://
and the Silver stone air Penetrator 121:
http://
noise isn't too much of a problem because the case has a built in fan controller for 2 fans but less noise would be preferable.
Thank you
http://
http://
Thank you
