Buying some ram today and wondering if it's worth paying the extra $8 to get 3600hz ram over 3200hz which is only $8 cheaper. Will there be any difference in light multitasking and gaming? Thanks.
What is the make and model of your motherboard and the processor you've paired it with? BIOS version for said motherboard would help. Also, please pass on the links to both ram kits in case there are any differences in latencies on both kits.
Worth is something only YOU can determine.
Will there be any difference, but likely minimal.
How much depends on your answers to Lutfji.
My take is that $8 is small enough that you will forever wonder if you bought the cheaper kit.
