Choosing CPU for Maximum Setting for ASUS A8N32-SLI Deluxe MotherBoard.
setha
53
Hi,
I am looking to purchase best CPU for ASUS A8N32-SLI Deluxe MotherBoard. My processor currenly is listed in Linux OS as AMD Athlon(tm) 64 FX -60 Dual Core Processor x 2, but I would like to change it for the one that would provide my PC the maximum setting. I have 4 Gb of RAM installed already. My power supply might currently be 500w or 550w.
I hope someone can guide me. I will probably try finding such CPU from Ebay. Please also note that my manual for this ASUS motherboard stated
CPU: "Socket 939 for AMD Athlon 64 FX/64 X2/64 and Sempron processor"
Thanks so much.
Thanks. I have just checked both of the links that you gave. I believe I already have the best CPU (2.6 Mhz), so I do not need to change it. The solution given here -> http://www.tomshardware.com/forum/297298-28-upgrade-a8n32-deluxe also mentioned the same.
