Chrome not loading pages properly and causing system to reboot without warning.
Dec 9, 2013
12
My computer crashes without warning when visiting certain websites (ie Bitcoinwisdom.com) and also some page will load incorrectly, such as Amazon which loads with a fixed search bar that does not disappear as you scroll down and covers parts of the page (amazon could not assist with fixing issue) It loads normally in IE but not chrome which is my main browser.
I've tried clearing browsing data, reinstalling windows 7, and updating all drivers to no avail.
I'm thinking it might be a hardware issue. I have no problems with crashing during more intensive use such as gaming, though, mostly just from web browsing.
Computer stats:
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-A75-UD4H
BIOS: Award Modular BIOS v6.00PG
Processor: AMD A8-3870 APU with Radeon(tm) HD Graphics (4 CPUs), ~3.1GHz
Memory: 8192MB RAM
Card name: AMD Radeon HD 6550D
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon HD 6550D (0x9640)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9640&SUBSYS_D0001458&REV_00
Display Memory: 4078 MB
Dedicated Memory: 495 MB
Shared Memory: 3582 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Some applications are conflicting with Google Chrome. Fortuntaely Google has a technology to display a list of all modules and figure out those modules which are not well functioning. To do so, write "chrome://conflicts" in the address bar and hit ENTER. You'll see couple of modules. Uninstall programs related to conflicting modules.
More diagnostic and repair info here:
http://www.slideshare.net/George420/chrome-flashcrashes
You’re experiencing this problem due to some unsupported device drivers. Fire up Device Manager and remove malfunctioning, unsupported devices. This will fix-up the issue. Using Chrome Repair Patch you can fix this problem automatically.
Run System File Checker:
1. Insert Windows Operating System installation disc.
2. Click the Start button.
3. Point to All Programs | Accessories.
4. Right click Command Prompt, select Run as administrator.
5. Type below command and press ENTER:
sfc /scannow
6. Exit when done.
Update Device Drivers:
1. Click the Start button, type “Device Manager” in the Search Box.
2. Press ENTER.
3. Expand top category from left panel.
4. Right click a device driver, select “Update driver software” option.
sfc /scannow
6. Exit when done.
Uninstall Malfunctioning/ Problematic/ Incompatible Device Drivers:
1. Click the Start button, type “Device Manager” and press ENTER.
2. Click View | Show hidden devices.
3. You’ll see malfunctioning devices will have a yellow color exclamation mark in beginning.
4. Right click a malfunctioning device, select “Uninstall” option.
With Google Chrome Troubleshooter you can quickly sort out this issue.
