Chromecast 3 (instead of Chromecast Audio) for wireless multi room audio
Hi.
Now that Chromecast Audio is discontinued, can I use Chromecast 3 for the same purpose... i.e., for each room, connecting CC3 into an amp connected to two speakers?
Since CC3 is HDMI and most amps are RCA, will I lose sound quality adapting from the former to the latter?
Thanks in advance!
You would need an HDMI audio extractor for each CC3. I suspect that you won't notice a change in sound quality. If you have better quality amps and speakers use a Sonos Connect or Denon Heoslink for much higher quality. You could also use Amazon Echo Dots or Connects which have analog audio outputs.
