Cisco C3560 switch - bandwidth control
Sep 26, 2018
11
Hi,
I would like to start off by saying that I am no tech expert like many of your here and my question will probably seem very simple.
I have a Cisco 3560-C-8PC-S switch (15.2(2)E8 used in a home environment and I have a single goal:
I would like to limit the maximum up/download speed for a certain LAN port.
I have done my homework and Googled for days trying to understand the posts that to me seemed overly complex and most are described using Telnet connection. Although I can login via telnet, instead of the CLI I would like to doing everything through the Cisco Network Assistant app (v6.3).
While playing around with the QoS / Rate Limit functions I managed to find a way to throttle the download speed for LAN port 1. However, the upload was not getting throttled, it was still much higher speed than the download. I would greatly appreciate the help of one of the many experts, if he/she could explain what needs to be done using the Network Assistant software to set this up properly.
Thank you so much in advance!
mls qos
ip access-list extended xxx
permit ip any any
class-map match-all limitport
match access-group name xxx
policy-map portlimit
class limitport
police 10000000 100000 exceed-action drop
interface GigabitEthernet0/1
service-policy input portlimit
Thanks for your reply.. however, like I said I don't have a lot of experience working with switches so I do not really know how set the things that you wrote.
If you could give me some guidelines how I can set this up using Cisco Network Assistant, I would greatly appreciate it! :)
Ps: I tried to check out QoS / Policies and configured a QoS policy but when I had to add a Class and I had to chose from DSCP / IP Precedence / ACL ... I was practically lost. :/
mls qos
permit ip any any
class limitport
Fantastic, thank you very much. Given that I am not an expert I am happy I managed to follow your steps and it works. :bounce:
Am I right that this only limits the upload speed for the given port and I still need to set Rate Limit to throttle the download speed? That I can do already, I just wanted to double check that the policy you sent me was not supposed to affect the download as well.
Two last questions if you allow me:
1. "police 10000000 100000 exceed-action drop"
The 10,000 for burst byte is enough? With all honesty, I do not know what it actually does but when I googled, I saw that many were saying it's best to keep it at maximum... was that nonsense? :)
2. For Rate Limit, the smallest value I can set is '10'. That results in 6mpbs upload speed. What can I do if I want to further reduce it to let's say appoximately 2 mpbs? (my max UL speed is 99 mbps).
Thank you very much once again, I really appreciate your prompt help.
You can experiment with the burst rate. You need to keep it as low as you can without it causing a artificial limit.
I am not 100% sure I did that correctly, i just keyed it in I did not put it in a actual switch. If I did this correctly it should limit to 10mbits. I think you can default the burst rate. I forget these details when I do not have a actual switch to key it in on. The ? option shows you lots of stuff.
Just apply a different policy outbound. You can use police or shape on a outbound policy. I forget why you do not use the ratelimit.
I forget many thing now that I retired it seems.
Your instructions were perfect and super helpful. There were smaller bits I had to figure out but that's because I no nothing about these. I have only dealt with household routers before so working with a Cisco switch is like sailing out to the wild seas for me... And yes, I did use the ? command to see what each option does.
Don't forget, I have zero experience in advanced networking... sorry but I don't know how I can tell if I am causing an artificial limit or how I experiment with it.
Yes, it limits the upload speed to 10mbits (actually, only 2mbits, because that's what I wanted to set so I used 2000000 as value).
Any chance you can help me do that? Looking at the commands you sent me, I cannot see which part is which sets that it's for inbound or outbound.
Because Rate Limit only throttles the download speed on that port and the upload is not affected by Rate Limit - that's what I found via Googling.
Thank you!
You could apply exactly the same policy if you wanted by using
service-policy output
on the ethernet interface.
In general you should use shaping rather than policing on a output policy. It give a much smother and better traffic control. It has a very similar command format to the police command.
You can make massively complex policies with this stuff with mulitple policier and shaper based on traffic markings and/or ip address ranges. That is partially why it is so complex because what you want to do is rather simple but you still must configure a bunch of stuff you are not really going to use.
Thanks once again. As I am completely unfamiliar with all this, could I please kindly ask you to send me the commands I need to go through to use the shaping instead of the policy.
Sorry to bother you with such novice questions... :)
Thank you. I am travelling for a few days but when I am back I will read into this. I will let you know if I managed. :)
Thanks!
