Cisco pix 525 problem
bahmeti1976
15
Hello Everyone,
I have had a cisco pix 515 2 weeks ago and for some reason it died. Now i have got a Cisco PIX 525 VPN Firewall and i loaded the same configuration i had on my previous PIX 515, All the links seem up and running but when i try to access my barracuda, or connect to my servers remotely from logmein they dont appear online on my Logmein web console and cant even be reached. Even my mail server can not send emails out nor receive. If anyone will be able to help me on this issue i would really appreciate it a lot because i am new in cisco PIX firewalls.
Here is the show config below:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password jqiZ8bp1ti4sUnO4 encrypted
passwd jqiZ8bp1ti4sUnO4 encrypted
hostname MRPIX
domain-name xxxxxxxxx.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
names
access-list acl_out permit icmp any any
pager lines 24
logging on
no logging timestamp
no logging standby
no logging console
no logging monitor
no logging buffered
no logging trap
no logging history
logging facility 20
logging queue 512
logging host outside 172.19.0.211
interface ethernet0 100full
interface ethernet1 100full
mtu outside 1500
mtu inside 1500
ip address outside 38.xxx.xxx.210 255.255.255.240
ip address inside 10.49.32.5 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
arp timeout 14400
nat (inside) 1 10.49.32.0 255.255.255.0 0 0
static (inside,outside) 38.xxx.xxx.215 10.49.32.242 netmask 255.255.255.255 0 0
static (inside,outside) 38.xxx.xxx.216 10.49.32.243 netmask 255.255.255.255 0 0
static (inside,outside) 38.xxx.xxx.211 10.49.32.250 netmask 255.255.255.255 0 0
static (inside,outside) 38.xxx.xxx.212 10.49.32.11 netmask 255.255.255.255 0 0
static (inside,outside) 38.xxx.xxx.213 10.49.32.254 netmask 255.255.255.255 0 0
static (inside,outside) 38.xxx.xxx.214 10.49.32.249 netmask 255.255.255.255 0 0
conduit permit tcp host 38.xxx.xxx.212 eq smtp any
conduit permit tcp host 38.xxx.xxx.212 eq 465 any
conduit permit tcp host 38.xxx.xxx.212 eq pop3 any
conduit permit tcp host 38.xxx.xxx.212 eq 995 any
conduit permit tcp host 38.xxx.xxx.212 eq 143 any
conduit permit tcp host 38.xxx.xxx.212 eq 993 any
conduit permit tcp host 38.xxx.xxx.212 eq www any
conduit permit tcp host 38.xxx.xxx.212 eq 443 any
conduit permit tcp host 38.xxx.xxx.212 eq ftp any
conduit permit tcp host 38.xxx.xxx.212 eq ftp-data any
conduit permit tcp host 38.xxx.xxx.209 eq smtp any
conduit permit tcp host 38.xxx.xxx.209 eq 465 any
conduit permit tcp host 38.xxx.xxx.209 eq pop3 any
conduit permit tcp host 38.xxx.xxx.209 eq 995 any
conduit permit tcp host 38.xxx.xxx.209 eq 143 any
conduit permit tcp host 38.xxx.xxx.209 eq 993 any
conduit permit tcp host 38.xxx.xxx.209 eq www any
conduit permit tcp host 38.xxx.xxx.209 eq 443 any
conduit permit tcp host 38.xxx.xxx.209 eq ftp-data any
conduit permit tcp host 38.xxx.xxx.209 eq ftp any
conduit permit tcp host 38.xxx.xxx.209 eq domain any
conduit permit udp host 38.xxx.xxx.209 eq domain any
conduit permit udp host 38.xxx.xxx.209 eq ntp any
conduit permit tcp host 38.xxx.xxx.209 eq 8081 any
conduit permit tcp host 38.xxx.xxx.209 eq 8082 any
conduit permit tcp host 38.xxx.xxx.209 eq 4899 any
conduit permit tcp host 38.xxx.xxx.209 eq 22 any
conduit permit tcp host 38.xxx.xxx.215 eq www any
conduit permit tcp host 38.xxx.xxx.215 eq 443 any
conduit permit tcp host 38.xxx.xxx.215 eq 1494 any
conduit permit udp host 38.xxx.xxx.215 eq 1604 any
conduit permit tcp host 38.xxx.xxx.215 eq 2513 any
conduit permit tcp host 38.xxx.xxx.215 eq 2598 any
conduit permit tcp host 38.xxx.xxx.215 eq 3389 any
conduit permit tcp host 38.xxx.xxx.215 eq 8082 any
conduit permit tcp host 38.xxx.xxx.215 eq 27000 any
conduit permit tcp host 38.xxx.xxx.209 eq 5060 any
conduit permit tcp host 38.xxx.xxx.209 eq 5061 any
conduit permit tcp host 38.xxx.xxx.211 eq smtp any
conduit permit tcp host 38.xxx.xxx.211 eq 465 any
conduit permit tcp host 38.xxx.xxx.211 eq www any
conduit permit tcp host 38.xxx.xxx.211 eq 443 any
conduit permit tcp host 38.xxx.xxx.211 eq pop3 any
conduit permit tcp host 38.xxx.xxx.211 eq 995 any
conduit permit tcp host 38.xxx.xxx.211 eq 143 any
conduit permit tcp host 38.xxx.xxx.211 eq 993 any
conduit permit tcp host 38.xxx.xxx.213 eq ftp-data any
conduit permit tcp host 38.xxx.xxx.213 eq ftp any
conduit permit tcp host 38.xxx.xxx.213 eq www any
conduit permit tcp host 38.xxx.xxx.213 eq 443 any
conduit permit tcp host 38.xxx.xxx.216 eq 3389 any
conduit permit tcp host 38.xxx.xxx.216 eq www any
conduit permit tcp host 38.xxx.xxx.216 eq 443 any
conduit permit tcp host 38.xxx.xxx.216 eq 8080 any
conduit permit tcp host 38.xxx.xxx.211 eq 8081 any
conduit permit tcp host 38.xxx.xxx.216 eq 4343 any
conduit permit tcp host 38.xxx.xxx.214 eq ftp-data any
conduit permit tcp host 38.xxx.xxx.214 eq ftp any
route outside 0.0.0.0 0.0.0.0 38.conduit permit tcp host 38.xxx.xxx.212 eq smtp any
route outside 0.0.0.0 0.0.0.0 38.xxx.xxx.209 1
timeout xlate 3:00:00.209 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
snmp-server host outside 172.19.0.211
no snmp-server location
no snmp-server contact
snmp-server community InnovativeNet
snmp-server enable traps
floodguard enable
no sysopt route dnat
isakmp identity hostname
telnet 199.xx.xx.226 255.255.255.255 outside
telnet 10.49.32.0 255.255.255.0 inside
telnet timeout 15
ssh timeout 5
terminal width 80
Cryptochecksum:9553cb531a69f18224cfc4662f57ace4
Thank You Very Much.
sk1939
Can you user authenticate remotely via SSH or Telnet? Can you ping from the outside to the outside interface of the firewall? Also, what version of PIX/ASA code were you running on the old device, and what version are you running on this one?
bahmeti1976
15
This Cisco PIX 525 has a unrestricted license. See below:
c i s c o S y s t e m s
Private Internet eXchange
Cisco PIX Firewall
Cisco PIX Firewall Version 6.3(4)
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 8
Maximum Interfaces: 12
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
bahmeti1976
15
Hi sk1939
Sorry i could not reply to your message earlier because i wasnt home. Anyways when i ping the outside interface it seems like its not working because its giving me the -- 0ms, Please see below:
MRPIX# ping 38.xxx.xxx.210
38.xxx.xxx.210 response received -- 0ms
I also wanted to ping google on its IP address 74.125.137.105, see below:
MRPIX# ping 74.125.137.105
74.125.137.105 response received -- 30ms
74.125.137.105 response received -- 20ms
When i run the command show interfaces it shows the following:
MRPIX# sh int
interface ethernet0 "outside" is up, line protocol is up
Hardware is i82559 ethernet, address is 0013.6009.4e71
IP address 38.xxx.xxx.210, subnet mask 255.255.255.240
MTU 1500 bytes, BW 100000 Kbit full duplex
4 packets input, 282 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
324 packets output, 29110 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/1)
output queue (curr/max blocks): hardware (0/2) software (0/1)
interface ethernet1 "inside" is up, line protocol is up
Hardware is i82559 ethernet, address is 0013.6009.4e72
IP address 10.49.32.5, subnet mask 255.255.255.0
1043 packets input, 92153 bytes, 0 no buffer
Received 487 broadcasts, 0 runts, 0 giants
341 packets output, 23668 bytes, 0 underruns
input queue (curr/max blocks): hardware (128/128) software (0/4)
output queue (curr/max blocks): hardware (2/7) software (0/1)
interface gb-ethernet0 "intf2" is administratively down, line protocol is down
Hardware is i82543 rev02 gigabit ethernet, address is 000e.0c6b.96f8
MTU 1500 bytes, BW 1 Gbit full duplex
0 packets input, 0 bytes, 0 no buffer
0 packets output, 0 bytes, 0 underruns
input queue (curr/max blocks): hardware (0/0) software (0/0)
output queue (curr/max blocks): hardware (0/0) software (0/0)
Just wondering if this PIX is OK or i have forgotten to ad a command to allow outside world see my network servers. I just checked and my mail wont go through nor be able to receive or even my servers will not show online when i try to reach them either through LogMein or even through web interface because i have public IP addresses on some of them. Any help would be greatly appreciated.
Thanks Again.
sk1939
Well first off, can you ping from any of the PC's to the outside interface? Looking over your commands it appears that you are missing NAT and configuration. Even with public IP's set to the servers, they still need to pass through the firewall. You can use ASDM to configure this if you are not familiar with the CLI.
bahmeti1976
15
Yes i can ping from any of the pc's, here is the output:
C:\Users\bahmeti.xxxxxxxx>ping 38.xxx.xxx.210
Pinging 38.xxx.xxx.210 with 32 bytes of data:
Reply from 38.xxx.xxx.210: bytes=32 time=3ms TTL=253
Reply from 38.xxx.xxx.210: bytes=32 time=1ms TTL=253
Reply from 38.xxx.xxx.210: bytes=32 time=2ms TTL=253
Ping statistics for 38.xxx.xxx.210:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 3ms, Average = 1ms
Can you show me what the command should be or show me how to put this NAT configuration that i am missing?
Thanks a lot.
bahmeti1976
15
Hi Sk1939, Please disregard that previous message i i replied you, i tested another pix firewall with a lower ISO image , i will check and see if i can ping the outside IP address later today. Thanks a lot for your responses and your help.
bahmeti1976
15
HI sk1939,
I just pinged the outside interface from 2 computers in my network and they both returned successfully, Please see below:
C:\Users\Admin>ping 38.xxx.xxx.210
Reply from 38.xxx.xxx.210: bytes=32 time=19ms TTL=253
Minimum = 1ms, Maximum = 19ms, Average = 5ms
C:\Documents and Settings\Admin>ping 38.xxx.xxx.210
Reply from 38.xxx.xxx.210: bytes=32 time=5ms TTL=253
Minimum = 1ms, Maximum = 5ms, Average = 2ms
If i am missing a NAT configuration can you please help me out with this because i dont understand NAT very well.
Thanks a lot.
sk1939
So you can ping the outside interface, which is good. Try pinging the following: 4.2.2.3 and 74.125.228.40
That link I gave you should explain most everything about NAT on the PIX.
Rich tea
4
hjk
bahmeti1976
15
I tried the ping from my computer from my LAN network. See below:
C:\Users\admin>ping 4.2.2.3
Pinging 4.2.2.3 with 32 bytes of data:
Reply from 4.2.2.3: bytes=32 time=18ms TTL=53
Reply from 4.2.2.3: bytes=32 time=9ms TTL=53
Reply from 4.2.2.3: bytes=32 time=10ms TTL=53
Reply from 4.2.2.3: bytes=32 time=2ms TTL=53
Ping statistics for 4.2.2.3:
Minimum = 2ms, Maximum = 18ms, Average = 9ms
C:\Users\admin>ping 74.125.228.40
Pinging 74.125.228.40 with 32 bytes of data:
Reply from 74.125.228.40: bytes=32 time=37ms TTL=51
Reply from 74.125.228.40: bytes=32 time=21ms TTL=51
Reply from 74.125.228.40: bytes=32 time=34ms TTL=51
Reply from 74.125.228.40: bytes=32 time=28ms TTL=51
Ping statistics for 74.125.228.40:
Minimum = 21ms, Maximum = 37ms, Average = 30ms
C:\Users\admin>
sk1939
That's your issue right there. That means that none of the computers that are part of your LAN can reach the internet. Likewise, internet traffic has no path past the firewall. You need a NAT statement for most of the PC's, and for those that are publicly addressable you need firewall statements that allow traffic through, as well as a route statement.
bahmeti1976
15
The ping worked successfully and all computers have internet connectivity. Maybe you didnt check the last reply that i made very well. Its just that i think that like you said i might need to add a NAT statement and a route statement as well.
Thanks sk1939
bahmeti1976
15
Its OK i know that you work too, but can you provide some examples on NAT and route statements. I know you sent me the link to NAT commands but i still dont get it right. I would really appreciate it.
Thanks
sk1939
The following example configures static NAT for the real host 1.1.1.1 on the inside to 2.2.2.2 on the outside with DNS rewrite enabled.
1.
hostname(config)# object network my-host-obj1
2.
hostname(config-network-object)# host 1.1.1.1
3.
hostname(config-network-object)# nat (inside,outside) static 2.2.2.2 dns
The following example configures static NAT for the real host 1.1.1.1 on the inside to 2.2.2.2 on the outside using a mapped object.
1.
hostname(config)# object network my-mapped-obj
2.
hostname(config-network-object)# host 2.2.2.2
3.
hostname(config-network-object)# object network my-host-obj1
4.
5.
hostname(config-network-object)# nat (inside,outside) static my-mapped-obj
However, you will need to allow them thorough the firewall, although the rules may have been transferred from the previous box. Who configured the old PIX?
