Hello.
Can someone help me out with finding the right cable to connect the side fans on this case?
Bought this pc for a bargain price and everything is working but not the controlled LED side fans and it drives me mad. I can seem to find the right cable + it doesn't look like I have any free molex cables to connect them anyway.
Maybe someone more experienced could help me out with a solution? I would appreciate if you could post a link to the right type of cable.
I'm guessing here but it looks like I need a molex cable + molex extension cable (as I have no free molex cables) and the other end should have two male pins that need to be plugged in the 2 fan female controller on the side panel.
I have found a video on youtube but unfortunately the quality is not the best and the guy doesn't quite explain what sort of a cable it is.
I have added a youtube link. [video="https://www.youtube.com/watch?v=GZsKFerPh2w"][/video]
Link to the case http://
I will try adding some pics to make things clearer.
https://imgur.com/a/UnpE6
Really hope someone can help me out as I can't stand when things don't work properly.
Thank you.
Thank you.
