Cleaning a cpu with a paper towel
Pcenthusiast16
Commendable
Mar 27, 2016
275
There is alot of division on this but is it okay to use a paper towel (kitchen roll) to clean a cpu? Ive used it before without a problem but i heard that it can 'scratch' the surface of a cpu, is this true?
Scratching i not the issue there. Small specks of paper dust go flying around, when you clean with paper towel.
But if you do everything carefully and blow paper dust away, then that's not really a problem either.
