G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I've done a google search and haven't found a straight answer to my
problem. Sorry if I am repeating a very old thread🙁
My iP4000 is printing erratically after just three month. Yes, I was
first in line when they passed out the stupid pills and refilled the
Magenta tank with yellow and vice versa. Yeah, I know, it only takes
one of those pills!
Bought new carts and still had a problem. Here's what I did:
To find out which cart was a problem, I created three rectangular
boxes in Pagemaker and filled them with C, M, and Y. When printed, I
get a brilliant three boxes of CMY.
Aha! sez I, the carts are correctly filled, installed correctly and in
the right slots.
Then I ran a test pattern and the cyan cart shows some streaking. So I
ran numerous cleaning and deep cleaning cycles but cannot get rid of
the white streaks in the cyan bars.
Questions:
1. Does this indicate clogging of the cyan nozzles?
2. If deep cleaning can't fix things, can I remover the print head and
soak it or otherwise clean it better than the deep cleaning cycle
does?
3. If yes to (2) what cleaning solution? Water and Windex? Muriatic
acid? Caustic soda? Alcohol? And at what temperature?
Yes, if this becomes a nightmare, I can always trash this printer and
buy another since it won't break the bank...just dent it pretty badly.
But this is a really nice li'l printer and I'd like to rescue it.
Any and all suggestions will be gratefully received. Thanks
DaveinFLL (Pixmaker)
It's not the heat, it's the humidity!
(...Think the humidity's bad?
You should watch us vote!)
one of those pills!
the right slots.
Questions:
does?
