L lightningg Commendable Sep 27, 2020 28 0 1,530 Aug 19, 2022 #1 can I use a microfiber cloth with a little bit of tap water on it to clean a spot on a LED TN monitor or do I risk getting dead pixels or something?
Solution Phillip Corcoran Aug 19, 2022 Using a microfiber cloth is totally okay but I wouldn't use water. Use a proprietary screen cleaning fluid which dries without leaving streaks.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,103 912 120,140 Aug 19, 2022 Solution #2 Using a microfiber cloth is totally okay but I wouldn't use water. Use a proprietary screen cleaning fluid which dries without leaving streaks. Upvote 2 Downvote Solution
