Cleaning PC case
-Chui-
Commendable
Aug 22, 2016
18
Hi, is it ok to use the exhaust of my vacuum cleaner to blow the dust inside my chasis?
And if not, what's the proper way to clean and maintain the inner and outer parts of my chasis? Thanks in advance
My suggestion to try:
Use only two front 120mm fans as intakes and one 120mm fan in the rear as exhaust.
You will get sufficient airflow.
If you use more exhaust fans, they will draw in unfiltered air from adjacent openings.
If you think you need more airflow, you can replace the intakes with higher cfm fans at the expense of added noise.
I would not unless it was a very low power vacuum.
Too high a velocity can spin fans to dangerous speeds.
A cloth is probably best, or perhaps some canned air.
The best option is prevention.
See if you can't set up a positive pressure airflow where all the incoming air comes from one source and is filtered.
What is your case?
Hi, my case is Deepcool Kendomen! I think it has a filter already but I always open the side panel of the case when I am using it, maybe that's the reason It still accumulated dust inside.
