[SOLVED] Cleaning pc from dust
svat
141
Looks like a decent idea.
One caveat:
Do not blow into fans allowing them to spin up way past their design point.
Immobilize the fan by inserting a screwdriver into the blades first.
Will second @geofelt regarding imobilizing the fan.
However I will add the recommendation that you use something soft and non-conductive.
A bit of dry soft sponge.
Just in case the air flow or some friend of Mr. Murphy shows up and the "immobilizer" goes flying or bouncing about in the case...
