jet399 Distinguished May 31, 2013 146 0 18,680 Jul 1, 2014 #1 Hi, So obviously you can buy compressed air cans from many places but how long will 400ml of air last? Thanks
Solution USAFRet Jul 1, 2014 jet399 : USAFRet : Depends on how generous you are with the trigger. Do this outside. Just short squirts across the whole case, will probably not be generous at all. It will probably last several cleanings.
USAFRet Titan Moderator Mar 16, 2013 179,749 22,084 184,590 Jul 1, 2014 #2 Depends on how generous you are with the trigger. Do this outside. Upvote 0 Downvote
jet399 Distinguished May 31, 2013 146 0 18,680 Jul 1, 2014 #3 USAFRet : Depends on how generous you are with the trigger. Do this outside. Just short squirts across the whole case, will probably not be generous at all. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,749 22,084 184,590 Jul 1, 2014 Solution #4 jet399 : USAFRet : Depends on how generous you are with the trigger. Do this outside. Just short squirts across the whole case, will probably not be generous at all. It will probably last several cleanings. Upvote 0 Downvote Solution
jet399 Distinguished May 31, 2013 146 0 18,680 Jul 1, 2014 #5 USAFRet : jet399 : USAFRet : Depends on how generous you are with the trigger. Do this outside. Just short squirts across the whole case, will probably not be generous at all. It will probably last several cleanings. Okay, cool thanks Upvote 0 Downvote
