Clearance issue what to do?
May 30, 2018
34
Hey guys so i just bought all my parts and put everything together but after assembling everything i noticed i cant tuck my top bracket in all the way because it is hitting my ram, which prevents me from closing my tempered glass side of the case to close, what do you guys recommend to do???
here is my build
PCPartPicker part list: https://ca.pcpartpicker.com/list/p8rdHh
Price breakdown by merchant: https://ca.pcpartpicker.com/list/p8rdHh/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($444.00 @ Amazon Canada)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler ($179.99 @ Amazon Canada)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard ($244.99 @ Amazon Canada)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3200 Memory ($283.23 @ Amazon Canada)
Storage: Samsung - 860 Evo 500GB M.2-2280 Solid State Drive ($176.99 @ PC-Canada)
Storage: Western Digital - Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($117.09 @ Newegg Canada Marketplace)
Video Card: MSI - GeForce GTX 1080 Ti 11GB ARMOR Video Card ($969.99 @ Mike's Computer Shop)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case ($124.99 @ Newegg Canada)
Power Supply: Corsair - RMx (2018) 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.99 @ Amazon Canada)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($117.75 @ Vuugo)
Total: $2809.01
Generated by PCPartPicker 2018-06-07 18:49 EDT-0400
i have a removable bracket at the top of my case and when i took it out to install the radiator and fans(push method) i cant put the bracket in all the way because the fans that attached to the radiator hit the ram
OK, I see. It appears to be a combination of mistakes by both Asus and Phanteks. Asus for designing their motherboard by placing the DIMM slots unusually close to the top of the board. And Phanteks for designing a gimmicky slide-out bracket for mounting the rad/fans on.
Any chance of mounting the rad/fan assembly directly to the top of the case like would normally be the way to do it and leaving out the bracket?
If the fans are hitting the RAM sticks due to their high heat-sinks, you could simply get shorter RAM. But it appears that it isn't the height, it is the slot placement.
