• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
[SOLVED] Click Sound from Laptop
Prashanth R
18
Hi,
I am hearing a click sound from my laptop. it comes occasionaly.
In the fan software , I see no FANS coming up.
https://imagizer.imageshack.com/img924/5802/lrEdUY.png
https://imagizer.imageshack.com/img924/4972/NJnSq9.png
The laptop is booting fine after BIOS update and have updated the audio driver as well. Checked the disk status of my SSD and HDD both are healthy status
Model : Lenovo Y700 - 15ISK
Can you please suggest here.
Thanks,
Prashanth
lukasus201010
17
The problem with the fan sound would be more repetitive than the occasional click. in my opinion it's 80% HDD
Sometimes disc check utility reports healthy status, but HDD is broken
try to remove HDD for a while and listen if there is click sound
white.a.drew
Respectable
Oct 14, 2017
960
59
2,290
61
Hi,
Thanks,
Prashanth
That could be several things loose capacitor and bad fan bearing. Would be the first two i would think
Prashanth R
18
Thanks for your reply. Could the upgrade of BIoS caused this? Or drivers update ? Or any softwares installed?
Does my screenshots look OK ? since it is not showing up any fans.
It was working fine till Sunday. From yesterday, I am hearing this sound.
Regards
Prashanth
lukasus201010
17
