Click to DVD Trouble
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.video (More info?)
Hi - I have followed the postings and have been able to save my MovieMaker
shows to AVI - then I use Click to DVD and it will not accept my blank disks.
When I use HP dvd+rw - it does not read I have a disk in the computer
When I use a CD-RW it says the "disk is not supported"
I have a Sony VAIO comptuer system.
Any thoughts or advice?
I have a Sony system also. If you go to the update section of the Sony
website, there is a download which fixes this issue...Good luck...
I do NOT have a Sony but I do have an HP 400i DVD Writer and recently
encountered this same problem (or at least the same system). Can you point
me to the appropriate fix... I tried navigating the Sony site but it was a
bit challenging since I did not have a Sony model to plug in 😱). Is it a
specific Windows fix... BTW, I am on XP SP1.
