Question Clicking noise (like hard drive clicking) no idea where it is coming from.
Jun 14, 2023
16
Hi all, been having this sound clicking issue for awhile now, fairly new pc build.
so basically the sound , sounds like a hard disk drive loading things, reading and writing. the kind when you start your pc and you hear it clicking, which is normal.
however I have no hard drives in the PC, only SSDs and nvmes. The sound comes and goes not necessarily when Im loading a game or it can come on when it's idle. it lasts up to a minute and comes and goes.
I have used afterburner to speed up my GPU fans and slow it down and the clicking noises do not get worse when speeding fans up.
Clicking sound can come whenever the pc is idle.
Here is a youtube link to a video i took.
View: https://www.youtube.com/shorts/YVLGPM9kkVg
in the video the sound is a little different than in real life. it really just sounds like a hdd reading and writing.
Im either wondering if it comes from the PSU / gpu or not sure if a motherboard can make those clicking noises.
My system info:
My system is a Asus rog Strix B-550F, 3080ti MSI Ventus 3x, amd ryzen 5 5600x, 32 GB ram
I think I found the problem, i downloaded a fan software controller and the noise would stop everytime I stop the Pc cooling fans that I added. so I removed them and so far no clicking sound.
Im trying to figure out how the fans made clicking noises, moving it manually it's not hitting anything.
They are those RGB DeepCool fans
It could be one of the fins out of alignment and barely hitting the outer shell of the fan itself or one could be warped. I got ahold of some a while back where the fins warped because of heat because they weren't well taken care of in the warehouse.
