clicking sound from hard drive
Saja__
My laptop is ok , and still working good. but while I'm on it , doing something, I hear discrete click sound that's coming and going sometimes , So Does this point to something? Or it's normal?
Clicks are generally not normal. It could be from a clogged cooling fan. You can address that with blowing out the vents with some compressed air from a can.
You should look at the SMART Data from the hard drive, and that will tell you the general health of the storage. Crystal Disk Info is a program that can do this, and there are others as well.
ermmmmm sorry but your laptops hard drive is dieing the clicks mean the header is starting to go off the platter so i suggest save any work onto a usb and any important photos because you could loose your data at any time
Most of the time clicking sounds in hdds are a bad sign. It could mean that the HDD is going to die or that parts of it are already dead. I would start to backup the data. Sometimes a HDD still works for quite some time after it starts clicking, but it could die any minute.
I really reccomend backup before diagnosis since you cannot slow down the rate at which a hard drive dies but you can always diagnose later after your data has been saved so usb external hdds anything just get copying one i hear constant clicks after a long session of work my hard drive was dieing then i wanted to cry i had work to do due in the next 3 hours i finished it and submitted it then took out my hdd plugged it into my pc and began copying everything onto my other hdd some sections it was really clicking and i was frightened i would loose my data i did everything had all the fans i had spare plugged into my psu and was cooling the hdd and keeping it slightly warm when needed damn i was a freaking harddrive wisperer ahahah i felt its pain lol after my data was copied i removed my extra fans said my good byes and it clicked and and the clicks got louder i was in shock at a point exactly two minutes after i turned off my extra fans the clicks stopped getting louder and they were at a constant pace i looked up at my screen and BSOD the hard drive had died i rebooted and no boot device was detected RIP
