Clock resets to 1969, battery wong charge or hold a charge, random shutdowns
Cam2363
39
Whenever I turn on my ibook the clock reads 1969, the battery says 5% and i can sometimes get it to 6 but then as soon as it gets turned off it goes back to 5, it says the battery has like 200 mah remaining but as soon as it gets unplugged it turns off, the battery wont hold a charge. It once held a charge but it wont anymore. And at random times it will shut off and the green indicator on the dc jack turns orange and i cant boot the ibook back up unless its green. Does anyone know whats going on? Any help is great!
Cameron
The battery i replaced a few months ago and the ac adapter works but it just doesnt seem to work the way it should, i can get into the os but the slightest bump makes it shutdown, plus i dont really have the money to get new parts and it worked in the past it just started having the problem a few months ago
it works but the connector on the end is screwed up, so it doesnt fit right and if you didnt see it, i dont have the money to buy new parts i dont care if its 15 dollars, plus if it is its probably garbage
Well i dont have the money and i just have it as a toy im not gonna dump money into it if i really wanted to use it i could just get another one on ebay for like 40 bucks
