Hi all, looking for someone to help me in English choose a processor for my new rig. The machine will be mainly used as a protools and adobe premier rig. I'm looking at the i5 series CPU's but am tossing up on getting the i5-750 or the 661. Both processors are around the same price but the, 750 has 4 cores, and a larger cache. The 661 has a much faster clock speed and is of the new 32 nm size, but is only a dual core. It is my limited understanding the premier would make use of the extra cores but protools(being the sh!thouse program that it is) won't? Any help would be greatly appreciated.
i5-750
- Number of Cores: 4 (Quad)
- Number of Threads: 4
- Clock Speed: 2.66 Ghz
- Max Turbo: 3.20 Ghz
- Smart Cache: 8 MB
- Bus/Core Ratio: 20
- DMI Speed: 2.5 GT/s
- Instruction: 64 Bit
- NM Process: 45
- Max TDP: 95 Watt
or the 661
- Number of Cores: 2 (Dual)
- Clock Speed: 3.33 Ghz
- Max Turbo: 3.60 Ghz
- Smart Cache: 4 MB
- Bus/Core Ratio: 25
- NM Process: 32
- Max TDP: 87 Watt
- Integrated HD Graphics (with compatible motherboards)
i5-750
- Smart Cache: 8 MB
- NM Process: 45
- Max TDP: 95 Watt
or the 661
- Smart Cache: 4 MB
- NM Process: 32
- Max TDP: 87 Watt
