looked at nvidia driver release note: (ver 416.81)
windows 10 issue with nvidia gtx 1080ti watchdog violations with certain systems with
motherboard with PLX chips. (not fixed)
Not sure what nvidia card you have but thought I would look it up.
the debugger reported that you had a unusual amount of hardware but when I tried to see what the hardware was the info was invalid. we are talking about low level hardware like PCI/e bus that the system thinks should be there but would not start. Is there any chance that the windows version was migrated from another motherboard? the debugger thinks you have about 3 times the hardware than any other system I have looked at. but almost all of the functions I would use to debug this in a kernel memory dump are not working. The data is not being stored where the debugger thinks it should be located.
here is what I would try next:
go into bios and toggle any setting, IE change something and change it back and save the results. This will force the bios to rescan the hardware and reassign the hardware resources and rebuild the database of setting it sends to windows plug and play.
second, you have a nvidia card and I think there was some kind of bug in the current drivers that had some issue with some interrupt multiplexer hardware. I don't know if it has been fixed or if you have this hardware but you might read the release notes for the GPU driver to see if it applies . (or go back to a older build of the GPU driver)
I would also, dump any non standard driver like the old 2011 USB charger driver you had installed.
it is used to override the Max current on a usb port so that apple devices can charge faster. This is a bad idea and your old driver has bugs that can mess up the USB ports. Since usb ports on newer boards run thru the PCI/e bus it can screw up almost all of your hardware.
The debugger also seemed to show that some items that should have been in the memory dump were not in the memory dump but were being stored on disk for some reason. I have seen this happen with certain viruses.
you might want to turn off the virtual memory to delete the pagefile.sys then reboot and turn it back on. it can help dump malware that is hiding in the pagefile.
you should also run cmd.exe as an admin then run
dism.exe /online /cleanup-image /restorehealth
sfc.exe /scannnow
this will try to fix any microcoft core file on disk, then run
a full shutdown to force windows to reload all of the files from disk on the next boot
(rather than used the compressed copies saved as an image)
shutdown /s /f /t 0
after that I would google "how to make a memory dump using a keyboard" make the registry settings and trigger a kernel memory dump while the system is working ok
then put up the working memory dump and I can see if the debugger works correctly and if I can read what hardware is not working.
I think the timeout is going to be some hardware that is not getting setup correctly.
you might go into device manager and turn off any high definition sound sources that do not have a speaker attached to them.
again, I think the problem is related to a pci bus that the system thinks is not actually starting up. The question is it really there or not. if it is then you might need a custom driver from the motherboard vendors website.
I will look and see if I can find the problem info with the nvidia driver
that relates to pci multiplexing devices. (these devices kind of fake the number of PCI/e lanes that the machine has.)
you also have a overclock driver running, it should be removed these tend to tweak voltages even if you don't ask it to. changing the voltages can change the timing windows in the electronics to the point where a hardware signal may occur before the hardware is ready to read the signal. in these cases the driver will wait for a signal that it has already missed, then it will timeout and cause a bugcheck.
I don't know if the problems I am having with the debugger are due to some change that Microsoft made with windows
you can also consider a reinstall of windows and reinstall of the current motherboard drivers. I would skip all of the motherboard utilities. Skip third party virus scanners and do all of the windows updates and see if the system is stable.
you had a specialized gaming rig, and it used many unique drivers. Some of these network drivers do some very nonstandard changes. Like expediting incoming packets and retarding the outgoing packets to give an advantage in gaming. (getting your opponent to shoot at your old location rather than your current location) anyway your ndis driver seemed to have been modified and I could not look at it in the debugger.
you should also look at the kernel memory dump setting maybe it is not dumping all of the required info? the size of the file seemed about correct so I don't know.
