Having decided to treat myself to a newer CPU, RAM and MOBO I have managed to pick up a Asus PRIME Z270-A for £82 in very good condition.
I will be purchasing a i7-7700K and 16GB/32GB of DDR4 3000/3200MHZ to go along with it. I plan to purchase a newer GPU in the next 12 months as mine is starting to show it's age at times in newer titles (MSI GeForce GTX 970 4GB GDDR5).
I've always used Artic Cooler Freezer's both on my E6320 and i5-2500K clocked at 4.5GHz currently in my S340 NZXT case.
I would like to try clock the new 7700K to a reliable 5GHz and don't know whether to:
A) put a big 240mm AIO in the front such as NZXT Kraken X52 (£115) or Corsair H100 V2 (£103) which I fear will make the GPU run hot as there is no space for any more fans on the front where this would mount and have read threads on here of people having GPU heat issues with the whole front case blowing air through a 240mm CPU AIO.
B) Keep the two 120mm intake fans at the front and buy a better air cooler e.g. Noctua NH-D15 (£80) or something better then a Artic Cooler Freezer 13 (£25).
C) Replace the single 120mm rear exhaust fan with a CPU AIO 120mm variant e.g. NZXT Kraken X42 (£108) or Corsair H55 (£63) if space allows or mount in the top 120mm exhaust fan. If niether fit I could replae the higher front intake fan so cold intake air is still blown freely over the GPU.
Air flow isn't the best in the S340 so not really sure which route to go, haven't had problems with my i5-2500k clocked to 4.5GHz but having spent a few hundred doing the upgrade I'd like the CPU to run cool whilst clocked to 5 (or as near as reliably possible with cooling in place). Plus when I upgrade GPU I don't intend to OC the GPU.
Advice please!
Advice please!
