Cloned Drive AND Original Drive Will Not Boot In Client's New Computer
Mr_Kreg
6
I have a client who's computer was freaking out. Doing some digging into it I found it was a motherboard issue and they decided to just buy a new computer and have me clone the hard drive on the old PC so it could just be plugged in and work with everything in the office.
Upon arrival of the computer I took the HDD out put it in the cloning cradle with the original and let the clone program do it's thing. An hour later it says it's done. I plug in the cloned drive and boot up the PC only to find a blue box saying "no boot source found, please install an operating system on your hard drive"
I went into the BIOS after seeing the message and the Hard Drive is not in the boot order list but if I go to storage it does see the hard drive as being connected through SATA.
So because there was nothing inherently wrong with the original hard drive I decided to plug that one into the computer instead to see if it would boot up but I got the exact same message!
I know I could just wipe the new drive and do a fresh install of windows but I was really hoping to just be able to keep all the files and settings which is why I thought of doing an upgrade install but that requires me to be able to actually boot to the desktop.
Basically I'm just trying to avoid having to reinstall windows and manually copy files and settings over if at all possible.
Cloning a drive and putting it into a new PC is no different than putting the original drive in a new PC.
It often does not work.
What OS is this?
What are the parts, old and new?
Bottom line, though...looks like you're in for a full OS install.
What OS is this?
It was a Windows 8 computer , the parts are new. The main thing is they're a construction company and they don't really understand how computers work. I think the only thing that's setup to be shared is Quickbooks and I don't have much experience with setting that up and neither do they since they had another company set it up awhile ago.
I don't think multi-user Quickbooks requires users to have the same operating system so if that's true I really just need to know how to set that up with the same settings as before if it's possible.
Quickbooks does not care what OS the files live on, or what the client systems are.
You just need to do a clean install on this new PC, and get the file sharing set up properly.
